-   -   Lower crank pulley HP500 (https://www.offshoreonly.com/forums/general-q/352507-lower-crank-pulley-hp500.html)
Donzi1979 02-26-2018 10:56 AM
10 Attachment(s)
I'm in the process of moving my power steering pump back to the Port side factory location on a 99 HP500. The boat had a M1 procharger set up and have removed all the relocation brackets, I noticed the lower crank pulley for the v belts from the procharger set up had the power steering belt pushed forward a 1/2 in. I realize these pulleys are no longer produced by Merc and the OE part number for the mine was 90081T. So I bought what I thought was the right crank pulley 90081C (just not high dollar merc blue I thought was the only difference) on ebay and you can see in the pic that the back side of the pulley where it should fit the face of the balancer is too small (which won’t center the pulley correctly). But according to many google searches this pulley should work as it used on small blocks and big blocks (which I know the center of the harmonic balancers are different) I'm just afraid it won’t center correctly. Also is it normal on a big block for the crank bolt/ washer to mate with the balancer and the pulley bolt on top of it? Hoping the OSO brain trust can help me figure this out.
Mbam 02-26-2018 11:00 AM
You really want the pilot diameter to match the balancer. You can have someone make a busing for you.
Donzi1979 02-26-2018 11:03 AM
Thanks Marc. I found another one ebay same casting number with a different raised section. Do you think this will work? What about the crank bolt does that look right and does it go on before the pulley. I'm pretty well versed on small blocks and know that the bolt passes through the pulley and and balancer.
Donzi1979 02-26-2018 11:04 AM
2 Attachment(s)
adding pic
Donzi1979 02-26-2018 11:05 AM
https://www.ebay.com/itm/Mercruiser-...19.m1438.l2649
Mbam 02-27-2018 06:58 AM
Yes, that looks like the one. If I remember correctly the balancer bolt does not clamp the pulley. The thick steel washer is behind. Just double check the depth on the balancer to make sure my memory is correct.
Unlimited jd 02-27-2018 07:02 AM
You are correct. The balancer bolt does not go through the pulley.
Donzi1979 02-27-2018 10:31 AM
Thanks for the replies, that's how I reinstalled the crank bolt. Now waiting on the other pulley.
