Gen4 w/retro-fit roller questions
Fuel Pump Push rod.
What are you using? Bronze tipped? Roller? OEM? Now the cam button. What timing cover is re-enforced for this? This Milodon listed on Summit states there is a "re-enforced" cover for use with buttons, but they only make it for small blocks. https://www.summitracing.com/parts/mil-65604/overview/ Milodon website confirms this. Milodon Timing Covers Forgive the questions, But I've been building Fords for 35 years... They use eccentrics for fuel pumps and thrust plates to keep the cam in place.. :-) |
No clue on the pump pushrod.. Went electric..
As far as the cam.. just use a GEN VI step nose core and cam retainer plate.. WAY easier than worrying about a cam button.. The holes are in the block for it... ;) JEGS Performance Products 200510: Camshaft Retaining & Thrust Plate OEM Style Plate w/ 2-Bolts | JEGS |
You would think in a retro fit cam kit they would mention something about either of these things.
Nothing about the button or thrust plate.. |
Solid or hydraulic roller, how much spring pressure ?
The material of the cam will dictate what fuel pump rod you need, check with manufacturer. Also, you may need to change distributor gear as well.
Mine required both a brass tip pump rod and a new distributor gear. (Add ANOTHER $75 to an already incredibly expensive upgrade). Good luck. |
Hydraulic. 377lbs
Originally Posted by GLENAMY 242SS
(Post 4613701)
The stock front cover should be fine with that spring pressure, Cloyes and a couple others have a timing gear with a bearing behind it, then use a solid aluminum or roller button.
Is it a step nose cam where you can use the retainer plate? I used the button on my old cams and would watch my timing cover deflect and timing move a little. I then put an aluminum spacer between my crossover/water pump to stop the deflection. Later when I changed cams out to stepped nose cams I then used the retainer. The nylon button was wore pretty good. I'm going to use the retainers on my new MK IV builds, but it looks like I might need to open up the bolt holes on the retainer a little.
Don't have it yet, but if not I will be switching to one with the step.
Do all the BBC's have the bolt holes for the plate or did the early stuff not have them? Edit: Answered my own question. "Some" of the early stuff did and some did not. Mine is drilled and tapped. So can use the gen 6 cam with trainer and also need to use the gen 6 timing chain set. |
| All times are GMT -5. The time now is 01:38 AM. |
