Which damper plate to use for 500hp and Bravo
I have a stock (recently new) oem merc damper plate. Its the triangle shape one (3 bolts I think). Do I need to be concerned with it being able to handle a power upgrade? I will be adding at least 100hp/tq to the 330hp it was intended for and wonder if its strong enough.
This build is killing my wallet and hoping I might be ok. Also im running a Bravo 3 so maybe its a good weak link in the chain to save the drive? Any advise here is appreciated. Oh and if I need to upgrade the damper will I need a different bell housing too? Right now what I have is the 330hp bravo stuff. |
i would update to a hp500 coupler,your bell housing is good,same as a 500.
I'll look it up and see if I can get one. Have you used my type and had a failure? or know of someone that has. Surely a more expensive stronger damper is better. I just want to know it's needed. |
https://rover.ebay.com/rover/0/0/0?m...2F162891771153 this is the style I currently have |
| All times are GMT -5. The time now is 06:50 AM. |
