-   -   454 gen v trimmings on new 502 6 gen? (https://www.offshoreonly.com/forums/general-q/352762-454-gen-v-trimmings-new-502-6-gen.html)
[email protected] 03-10-2018 04:08 PM
Will my 454 gen v accessories, ignition system and exhaust etc work on a gen 6 502?
Unlimited jd 03-10-2018 04:19 PM
Yes 5-6 will interchange. 5 to mk iv gets tricky
Rookie 03-10-2018 05:56 PM
Yes, lots of washers behind brackets and smaller bolts. Did that last year.
[email protected] 03-10-2018 10:33 PM
Did you guys upgrade cams? Looking at new 502 1800runsnew
Unlimited jd 03-10-2018 11:33 PM
Do some google searching on 1800 runs new. I’d order a gm zz 502 instead.
Griff 03-11-2018 01:18 AM
It should be called 1800run away:lolhit:
sutphen 30 03-11-2018 08:38 AM
what exhaust do you have and heads,intake,carb and comp. ratio?then we can pick a cam
[email protected] 03-11-2018 10:24 AM
I've had good luck with my new 1800runsnew 300hp 5.7.
i wouldn't buy a reman unit.
Unlimited jd 03-11-2018 10:53 AM
Are you Matt from Brisbon diesel? If so this is James Dow. Lots of better options than 1800
[email protected] 03-11-2018 01:30 PM
Yes sir, hi James hope all is well, any better sites?
