Cold Start Backfire and other questions about my new build
I'd be more worried about the timing vs a fat quadrajet. Do SBC Vortec heads like less timing like the BBC Vortec?
Well the carb ended up needing to be rebuilt. Timing and advance were set properly. No more hard start, backfiring, choking off idle, etc.. The boat runs very strong now and I'm pretty happy with this new build.
Factory 350 260hp that came in the boat got me 48MPH GPS.
New (rebuilt) 350 with vortec heads, aluminum intake, xtreme marine cam - 57MPH GPS!!
A 9 mph gain is huge. You probably added 100-140hp over what you had.
Old engine was probably tired so I'm betting you're in the 350-375hp range now.
Better keep some $$ set aside for an Alpha drive. You're pushing the limit for an Alpha.
Thoughts?
I'm only seeing 4500 RPM currently trimmed out at WOT. I have a Mercury Vengeance 21P Prop. Is it safe to turn a factory (rebuilt) bottom end and Alpha one to that range? What pitch prop would get me there? I'm VERY interested in seeing what top speed might look like with this build. I'd imagine another 1000 RPM and peak power of that cam would put me well into the 60's!
Thoughts?
Thoughts?
What ratio is the drive... Something seems off to me. My 22 foot tub is less efficient that the scarab as it is heavier and has a deeper V. GRanted I have a 454 but uts the 310 hp efi mpi. I am right about 60 with a 23 mirage at 4700 rpm. You should be winding a lot higher than 4500 with a smaller diameter 21p prop.
