-   -   Winterizing problem and GRW impeller update... (https://www.offshoreonly.com/forums/general-q/35305-winterizing-problem-grw-impeller-update.html)
Bill272 10-21-2002 10:46 PM
Well I started to winterize yesterday and Stbd motor went just fine. Swapped the muffs, turned on the water and fired up the port motor. I picked up some stuff in the boat, started cleaning out the glove box while it warmed up and went back to check things out. At that point I noticed I had NO water coming from the exhaust!!! It had been running for maybe 5 minutes like that, and the temp gauge was showing around 160. The exhaust was hot, but not too hot to touch.
I pulled off the intake hose and cranked up the hose and water was flowing thru the drive. Then I pulled the water pump to check out the impeller. 5 minutes running dry and it was fine. Someone had asked in another post if they take on a set, and it had taken a bit of a set, probably no more than a merc replacement. I'll be working on it tomorrow to figure what went wrong, but I thought I'd give an update on how the GRW blue impeller was holding up. They claim that they can run for 15 minutes dry, but I don't think I'll try that...
mopower 10-22-2002 06:39 PM
Cool:cool: Thanks
Vinny P 10-22-2002 09:04 PM
Where are you guys getting GRW Blue Impellers from??
Bill272 10-22-2002 09:47 PM
I got mine from www.boatfix.com.
http://www.boatfix.com/bymfg.ASP?mak...+WORKS%2C+INC.
Vinny P 10-23-2002 07:46 PM
Thanks Bill....
