-   -   Exhaust Manifolds (https://www.offshoreonly.com/forums/general-q/353131-exhaust-manifolds.html)
spaniard 04-01-2018 08:15 PM
Exhaust Manifolds
I noticed some seepage coming from my risers, so I replaced the gasket today. I also noticed corrosion on the exhaust manifolds. It's a 502 and put 400 hours on it now. How much longer do I have before I should replace the exhaust manifolds?https://cimg9.ibsrv.net/gimg/www.off...ddd7764c51.jpg
Close up,lower exhaust
https://cimg0.ibsrv.net/gimg/www.off...c52d6f343b.jpg
, rust is getting soft.
Griff 04-02-2018 01:45 AM
The longer you wait, the more you risk destroying an engine.
Bondo 04-02-2018 08:01 AM
Ayuh,.... The failure point is that gasket matin' surface, that you didn't post a picture of,......
The rust ya do show, is irrelevant,....
spaniard 04-02-2018 10:18 AM
https://cimg8.ibsrv.net/gimg/www.off...6b9850c15.jpeg
Bondo 04-02-2018 10:33 AM
Ayuh,..... That's Better, but not good enough,..... The gasket is still there, blockin' the view of the top of the manifold,......
What yer lookin' for is the Width of the iron wall 'tween the water passage, 'n the exhaust passage,....
Pull the gasket off, 'n clean the top of the manifold with a big ole flat file, to clean fresh cast iron,....
The flat file helps ya keep the finish surface Flat,....
Once that is done, the iron wall I mentioned needs to be a minimum of 3/16" wide to support the gasket,....
If thinner, failure is just 'round the corner,.....
spaniard 04-02-2018 10:39 AM
Thanks for the information, really appreciate the help. I'll just throw in a new one, rather than risk the engine, thanks again
Bondo 04-02-2018 11:09 AM
Ayuh,...... Any time,..... ;)
badbug 04-03-2018 10:54 AM
run in salt water or fresh water?
spaniard 04-03-2018 01:53 PM
fresh water
GLENAMY 242SS 04-03-2018 02:49 PM
Check with SHUNTER here on OSO (Houston, TX), I know he just removed a set of stock manifolds from his 502 for aftermarkets. His are in pristine shape. I don't know if he is wanting to part with them, just a suggestion. Good luck
