-   -   I think i lost TDC. HELP (https://www.offshoreonly.com/forums/general-q/353242-i-think-i-lost-tdc-help.html)
snowman51789 04-07-2018 12:30 PM
I have a 98 454 MAG MPI gen 6. I did a leak down test and determined the intake valves were leaking, I took the heads off had them rebuilt. when I took the heads off I was following the mercruiser #23 manual, I found TDC for cylinder #1 then began disassembly. im 95% certain that I did that step correct. however today I started reinstalling the push rods and rockers (in there original places) and when I got to cylinder #1 exhaust valve I noticed that as I was tightening the rocker bolt down, it started to depress the valve. I am new to working on V-8s but I have a lot of experience with Dirt bikes, snowmobile, etc.
if I am at TDC shouldn't the intake and exhaust valve be fully closed?
when I had the heads off piston #1 was all the way up. my worry is that I may have pushed the valve into the piston and damaged the valve or piston, when I was tighting the rocker bolt I did not notice any abnormal resistance until the bolt bottomed out.
any help would be appreciated
thanks
Dave
F-2 Speedy 04-07-2018 12:37 PM
sounds like your 180* out on the exhaust stroke, if Im reading right
Griff 04-07-2018 12:40 PM
Did you remove the cam or replace the timing gears??? Are you using the shorter pushrods for the intakes??
snowman51789 04-07-2018 12:42 PM
but even at 180* shouldn't the exhaust valve be closed? just my thinking, please correct me if im wrong
all I did was remove the heads, since I never touched the timing chain or the cam, (I did remove the distributor) is it possible for me to have any piston to valve clearance issues?
snowman51789 04-07-2018 12:45 PM
no I did not do anything with the cam or timing chain, im using the original push rods. I bagged them and marked the bag's with the cylinder number and intake or exhaust. are the intake pushrod's a different length then the exhaust pushrods? are you suggesting that I mixed them up?
Griff 04-07-2018 12:52 PM
Exhaust valve should be closed either way. It will start to open a just after TDC.
With what you have done, there should not be any clearance issues.
The stock shoulder bolts for the rockers should just need to be torqued down and it really shouldn't matter what cylinder is at TDC.
You will really only need TDC on #1 to set the distributor at the correct position.
Griff 04-07-2018 12:55 PM
Exhaust pushrods are the longer ones so that should not be an issue for you either.
AllDodge 04-07-2018 01:11 PM
Agree with speedy, your 180 out.
You thought you where on TDC, so 180 out puts you at the end of the exhaust stroke
Edit:
Guess, could also not be 180 out if the exhaust lifter is not sitting all the way down on the cam, kind of hung
GPM 04-07-2018 01:41 PM
TDC will come up on the damper at 1 and 6, see which cylinder has both valves closed and that's the cylinder you're on.
F-2 Speedy 04-07-2018 03:24 PM
rule of thumb to find TDC put your finger in the #1 hole and spin it around if it doesn't push air out the exhaust valve is open one more time around pushes your finger out with air, compression stroke for TDC.
Edit: and make sure the push rods are in the correct hole as mentioned.
bck 04-07-2018 07:12 PM
You mentioned that you found top dead center but you haven't said that you've verified it was top dead center on the compression stroke. Like F2 said, you need to verify which stroke it's on.
Young Performance 04-07-2018 07:33 PM
If you doubt that you are at TDC on the compression stroke, then rotate the engine by hand while watching the #1 intake pushrod/lifter/rocker arm. It will open and then close. When the balancer hits 0 after the #1 intake valve closes, you are on the compression stroke. You can't go wrong by just tightening them down as they have a non adjustable valvetrain. Sometime the lifter will pump up with oil and not release fast enough when you crank down on the rocker causing the spring to compress. It will eventually go down. It usually only takes a minute or so.
Eddie
justfishing 04-07-2018 11:41 PM
The cams need to be set in relation to the pistion. The Piston doesn't care if it compression or exhaust. Set #1 Piston at tdc. Then index the markings on the cam gears . If this is not an interference engine then you are free to rotate the cam with the heads on. Once set the timing chain keeps the rotating parts rotating in squence.
Griff 04-08-2018 01:56 AM
Since the cam and timing chain set have not been touched, just torque down the non adjustable rocker shoulder bolts to I think 35 ft lbs.
Correct, but can't do or see that until the rockers are installed.
