-   -   ARP head studs 525 EFI (https://www.offshoreonly.com/forums/general-q/353307-arp-head-studs-525-efi.html)
F-2 Speedy 04-10-2018 05:33 PM
anyone have a part # for the Mercury 525 EFI with the Edelbrock alum heads
stud kit not bolts
TomFTM 04-12-2018 08:48 AM
I dont have the part number for the studs, but I do have a set of cometic head gaskets for standard bore 525 efi, part number c5760-40 , I put one of them on the block (block honed .005 larger) and saw that it was too close to the cylinder bore size , the other is still in the package(untouched) . Both are in original package . I went larger bore on the gasket. I will sell them for $150 including shipping . Tom
mike tkach 04-12-2018 08:55 AM
i am pretty sure it would be the same as a gm iron head,why do you want to use studs?
F-2 Speedy 04-12-2018 09:01 AM
thanks Tom, I just bought two sets
Mike T....blowers are going to be installed, I just prefer studs over bolts
F-2 Speedy 04-12-2018 09:45 AM
I found a old OSO post that states they use the same bolt kit as the Brodix heads ?? part # 135-3609 this true ?
Young Performance 04-12-2018 09:51 AM
That is correct.
F-2 Speedy 04-12-2018 09:59 AM
Originally Posted by Young Performance (Post 4621222)
That is correct.
thanks
