-   -   6V-71 Recomendations (https://www.offshoreonly.com/forums/general-q/353360-6v-71-recomendations.html)
Mohavvalley 04-13-2018 09:19 AM
Picked up a 6V-71 which is a shorter 4 chamber, straight housing, dual helix rotor 6-71. The body is 12" (not including end plates) compared to a standard 6-71 which is 15" main body. Based on the research I've done and the stamping that's on it, it's a 358C.I.
I have most of it figured out but the carb(s). It'll have two intake cathedrals, approx 4.375" by 3..875 ( I can machine it it out a little if need be). The problem I see is the openings for the carbs are only 1" apart in the center. So if I need to run 2 carbs I'll have to fab up a dual riser that V's out to get enough clearance to mount 2 carbs side saddle. I'm assuminga1" of clearance is not enoughe to run 2 750's side saddle? If I go with one carb, I can buy a single carb adapter plate with riser and be done with it.
So the big question, on my 525SC, with EQ320 or Brodix DS 320 heads, and a roller, running this 358C.I. 6-71 do I need to run 2 carbs or 1? And what size carbs would you recommend I look at?
tbanzer 04-13-2018 10:10 AM
Im running one on a small block Chevy duel 1850 600 holleys.
Baja Rooster 04-13-2018 11:41 AM
Two smaller carbs are almost always better than one big one, when possible. Better fuel distribution.
Mohavvalley 04-13-2018 12:29 PM
What carb intake adapter did you use, you got any pics?
BBYSTWY 04-14-2018 06:27 PM
Check with Dyer's blowers over by Chicago...I think they deal with the 6v-71s
Mohavvalley 04-15-2018 01:43 AM
Called dyers Friday, they said they "only service and rebuild blowers and that they sell no parts" despite having parts listed on eBay and their website having pictures of custom cases, end caps, etc
I'm really sure I do not want to deal with a company/people that have no idea what they do or do not do!
BBYSTWY 04-15-2018 04:53 AM
hmm that's weird...they have always been very knowledgeable and helpful whenever I've talked with them...maybe its specific to the 6v-71 that they don't have parts for??
tbanzer 04-16-2018 09:49 AM
Mine came as a kit from Dyers Back in the 80s. Car is in storage so not able to get you any pics. it was just a 3/4" aluminum adapter bolted to the top of the blower
