Fuel pump location
I have an aeromotive fuel pump i want to use on a 496 ,I am not sure where to position the pump? Aeromotive say run the fuel line from the fuel tank to a 100 micron pre filter then fuel line to the pump from the pump a fuel line to the water seperating filter then to fuel rails. Whipple say to run the fuel line from the fuel tank to the water seperating filter then fuel line to the pump and then to the fuel rails |
Ayuh,.... Any filters should be on the vacuum side of the pump,.....
So the water seperator filter that filters 10 microns should go on the inlet side of the pump even though aeromotive say not to use an inlet filter less than 100 microns |
I put my aeromotive low as possible in the bilge after the merc filter/separator, then the 10 micron in line filter just before it enters the fuel rail. Was told them pumps like to push fuel ,not pull from the tank.
I thought the fuel pump likeed to push the fuel too thats why i thought the smaller 10 micron filter would be better after the pump and the larger 100 micron before the pump |
I have been down this road. I used to have the 100 micron then then the pump then the water separator to the rail. but this is wrong first you don't want 50lbs of pressure going to the water separator. just scrap your 10 micron completely. go from tank to water separator then to the pump as low as can go and as big a line as you can do. my tank actually has two pickups so I use both into a aeromotive fuel block to a 1/2" or 5/8" line to separator and big to pump then out of pump to rails my rail was modified by Eddie Young and It feeds both ends of the rail on a 502 MPI then out of the rail to the regulator and the return goes back to my fuel tank. I quit using the aeromotive fuel filter completely and I also had a fuel cooler that I know longer use either.
Oh great thanks i am installing a whipple and thats how their instructions read. it was after reading the aeromotive instructions where they say to run a 100 micron filter before the pump that i wasnt sure where to locate the pump |
Originally Posted by kip4234
(Post 4624777)
the fuel separator is 10 micron also, you can run another one if you want before the rail.
Thank guys Ok so I will be running the pump after the seperater /filter what size line are you running from the pump to the fuel rails |
Originally Posted by AusScarab29
(Post 4624877)
Yes whipple do say to run 3/8 line they also supply 3/8 fittings this whipple kit is for a stock 496. my engine will be around 800 hp so i was thinking of running 1/2 inch line to the rail |
| All times are GMT -5. The time now is 08:46 PM. |
