-   -   Fuel pressure loss at high rpm (https://www.offshoreonly.com/forums/general-q/353750-fuel-pressure-loss-high-rpm.html)
Sonichunter 05-05-2018 02:20 PM
Originally Posted by Baja Rooster (Post 4624964)
Did you actually pull the pick up tube out of the tank? Eddie young has often found some funky install issues there from the factory.
No I haven’t. I tried once. It’s on there pretty good to the point I was flexing the tank bad. Too nervous about breaking it.
AllDodge 05-05-2018 03:08 PM
BTW is the fuel pressure gauge mechanical or electrical?
Sonichunter 05-05-2018 03:39 PM
Electric. I’ve tried 3 different senders and 2 gauges. I ran a remote mechanical off the fuel log and it showed the same result.
Sonichunter 05-05-2018 03:42 PM
I guess at this point it has to be either the pick up or carb. I just can’t wrap my head around how it could be the pick up since I’ve tried it directly out of a gas can with same issue. I don’t know much about carbs either so not really sure if that logical but easy enough to be worth a try.
phragle 05-05-2018 04:48 PM
that KE unit replaces the head on the pump...do you still have the stock head??? how is the belt / tension/ pulley condition????
Sonichunter 05-05-2018 05:54 PM
I have replaced the upper with a stock one. I’m not aware of any upgrades for that. Same thing on the other engine. Doesn’t seem to be any bearing play. Pulley rotates easy and no wobble. Belt tension is good but really don’t know how to tell if it’s slipping at rpm. I will put a new one on and try it. Thanks.
justfishing 05-05-2018 07:05 PM
I doubt it would be the carb. With such a drastic drop in pressure would indicate a stuck float and dumping a lot of gas in the engine. It would bog down and you would have black smoke and stall.
I would replace the fuel lines. Marine fuel lines are different than auto. Marine lines have to be vapor impermeable. Marine lines have a liner that can come lose and cause a restriction or worse come apart and plug filters, injectors etc.
Sonichunter 05-05-2018 10:50 PM
Originally Posted by frickstyle (Post 4624936)
Whenever I lost pressure, it was a dirty/plugged filter. I run Fuel/Water sep > 100 micron > pump > 10 micron > dist block w/ return regulator > carb. Is a filter getting dirty? (This is on an electric pump setup).
ALSO, I just noticed one of my lines might be getting restricted coming out of the bulkhead, turning 90deg. I saw it dropping on the gauge last time out, but put the boat away before I could determine root cause. (Filters looked good when I changed them).
Check to make sure you have smooth transitions, and no kinks or collapsing. For it to happen on only one, something is being restricted, or the pump is whooped? (Some of this sounds elementary, which you have probably already checked).
i have checked all that...I appreciate the reply though
Sonichunter 05-05-2018 10:54 PM
I’ve replaced all the fuel lines with marine grade. Tank to carb....
blaquebaja 05-06-2018 03:49 AM
Swap the water pump with fuel pump then see what happens
