-   -   Cam bearing material? (https://www.offshoreonly.com/forums/general-q/353752-cam-bearing-material.html)
Mohavvalley 05-03-2018 06:03 PM
Getting my machining done and need to install new call bearings what's better material to go with, babbit or Silicon aluminum (Si)?
My spring pressures are 160/400, 1.7 rockers, 629/612 lift.
14 apache 05-03-2018 08:04 PM
I would go babbit think its better for dirt
Mohavvalley 05-04-2018 01:31 PM
So the general consensus is babbit and not aluminum silicon?
14 apache 05-04-2018 02:47 PM
Dart blocks come with babbit. Just use durabond bearings they are probably the best.
Mohavvalley 05-05-2018 11:40 PM
Ok durabondbond babbits it is, thanks Apache
BillK 05-06-2018 08:15 PM
I will second the Durabonds. That is all I use.
Rookie 05-06-2018 08:56 PM
I just bought/used 2 sets of Durabond myself.
Mohavvalley 05-10-2018 02:46 AM
Are you also using durabonds on the rods and mains over clevite or king or are you just using them on can bearings?
BillK 05-10-2018 07:05 AM
Durabond only makes camshaft bearings, not mains and rods. I have had very good luck with Clevite bearings over the years and dont like to change just for the sake of changing :) I have tried some King bearings lately but they seem to vary a lot as far as thickness goes :( Interesting since one of their selling points is their "bullseye" tolerance.
convincor 05-10-2018 09:54 AM
Durabond does offer a "coated" option if your going have it sitting for a while with spring pressures on the cam.
Had a cam bearing spin once because of this.
