Imco/Bravo gimbal bearing
Working on an Imco SCX transom assembly, 2010 yr.
Are the bearings the same? Also, I see from a Imco parts breakdown, it shows a gimbal bearing housing. Does that need removed in order to replace the bearing? The manual also states the bearing is a serviceable item......as in remove, clean, grease, and reinstall? This one is throwing me for a loop. Always considered them as replaceable. Just thinking since they cant be greased as the old Bravo TA's used to be, they make them 'servicable'. Can anyone confirm this? Still googling the Imco service procedures and not having any luck with Imco TA's, so in the mean time asking here. Thanks |
| All times are GMT -5. The time now is 11:47 AM. |
