TBI on a bbc marine application. Bad idea?
I was gearing up to try the Sniper system on my 509 with air gap intake but heard that the single carb on a bbc is bad enough at distributing the mixture as it is, but a TBI with its finer atomization compounds the problem. Approx 550hp. Any real world experience on this? |
I can't comment on the fuel distribution issue, but have helped an individual with a BBC and bored out big injector TBI. Ran fine but pulled vacuum at WOT due to insufficient air flow. This even with the bigger bore TBI. Cam and heads were very mild too.
Originally Posted by Trash
(Post 4627714)
run 2 or 3 tbi's,problem solved.
I have always wanted to try and run two TBI's on a dual 4 barrel intake.
You would have to be experienced with tuning, or know someone that is. My stock 5.7 EFI Merc has the big block TBI on it. They adapted it to a tiny 2 barrel intake. We will see if it still has vacuum at wide open throttle on my 383. If it does maybe next year I will try and run two of them. |
Don’t use a dual plane intake manifold. |
Originally Posted by sutphen 30
(Post 4627755)
Originally Posted by Baja Rooster
(Post 4627812)
Lol. So I’m ignorant on the Tech, but what’s so different between the Merc TB on the Merc MPI and a 4 barrel TBI? Is it the huge plenum or the lack of fuel thingamajiggers in the venturies? |
So this is a project/Topic i have a special interest in and have been doing tons of research on it. I'm a firm believer that EFI is far superior to a carb any day and all day. but i can save that lecture for a different day.
thread i have started on it https://www.offshoreonly.com/forums/...aps-350-a.html gear head EFI will have stock truck bin files and the matching .xdf files
Originally Posted by Paxtonspeed
(Post 4627771)
You would have to be experienced with tuning, or know someone that is. My stock 5.7 EFI Merc has the big block TBI on it. They adapted it to a tiny 2 barrel intake. We will see if it still has vacuum at wide open throttle on my 383. If it does maybe next year I will try and run two of them. The unmodded TBI units should be (i can post the math if needed) 5.7L SBC 2x 1-11/16" ~=490 CFM 7.4L BBC 2x 2" ~= 645 CFM a 350 @55000 @ 0.85 VE =~474 CFM No such thing as zero vacuum at WOT in a NA engine. Each piston on it's downward stroke with intake valve open, creates vacuum to pull the intake charge in. Equal pressure on both sides of intake manifold creates NO air movement, it's physics. Holly assumes a 1.5" pressure drop across the carb, so you should not see "0" vacuum.
Originally Posted by hogie roll
(Post 4627811)
Don’t use a dual plane intake manifold. Engine Masters ran into the issue you were talking about. |
My Innovation 540 CI 600HP engines had Holley TBI and they were GREAT!
| All times are GMT -5. The time now is 01:22 AM. |
