Fuel pump not kicking on with key 500 efi
check voltage at the electric fuel pump if you have voltage most of the times its a bad fuel pump. If no voltage then possible fuel pump relay or connection issue. Is this app a saltwater app ??? corrosion issues more times than not if SW usage.
