Trim TAB Question
A generic question... when the tabs are full up should they be even or tilted up from the hull running surface. And how far should the tilt up be?
thanks |
They should be tilted up from the running surface. How much, depends on the tab and the transom angle but I'd say a good 10-15 degrees. If you have tab gauges, most people adjust the gauges to read '0' when the tabs are aligned with the bottom of the hull (horizontal). RR |
When you buy tabs to install yourself the instructions will generally say that you have to run a straight edge off of the hull bottom to the end of the tab . At that point the end of the tab should fall X amount of inches above the straight edge when fully retracted . I believe it's something like a minimum of 1.75 - 2"
| All times are GMT -5. The time now is 07:54 AM. |
