-   -   Question re: MSD 6m-2L / blaster ss Ignition problem (https://www.offshoreonly.com/forums/general-q/354721-question-re-msd-6m-2l-blaster-ss-ignition-problem.html)
eichhoma 06-18-2018 09:21 AM
How is best way to tell if the ignition box took a dump or just the coil??
While running the other day, the port motor just shut down... seconds before it happened, all gauges showed to be good; good oil, fuel pressure, temps, etc.... motor just shut down.
trying to restart it just turns over and over with no spark or fire at all... doesnt even try to sputter or cough or start.... should I throw a coil at it first or should I assume with so many of the bad reviews out there that the box went out?
Thoughts? Thanks....
payuppsucker 06-18-2018 09:39 AM
Swap coils from the running motor first but it's probably the box. I've had both fail within the past year.
SB 06-18-2018 09:54 AM
Nothing quite like having bad box :(
MSD = My Sparks died
ezstriper 06-18-2018 06:38 PM
there is a test on MSD site(and instructions for a box to test it. betting box...MSD May Soon Die...
SS496 06-20-2018 08:29 AM
Many Suspicious Devices
Yes MSD has a diagnostics part in the manual....should be on the website if you dont have the manual. This is why I carry a known good HEI in my boat for an emergency spare.
eichhoma 06-22-2018 10:49 AM
so, I replaced the coil.... that didnt work, then I replaced the MSD box to a known good one and still no fire... now im stumped... I guess I should start looking at the distributor? coil wire? this is quickly getting above my knowledge grade
BBYSTWY 06-22-2018 11:05 AM
silly question but the kill switch for that engine didn't get pulled did it?? also I would check input power and ground into the box and make sure you didn't lose a power or ground source....then if that still doesn't work I would look at the module in the distributor....you have a known good one right next to it so you could always pull that one and swap it into the "bad" one and see if that does it...that way you're not buying useless parts
Stewart
payuppsucker 06-22-2018 11:25 AM
This^^^^^^^^^^and as mentioned earlier there's a fairly simple troubleshooting table on MSD website.
SB 06-22-2018 11:29 AM
^^^I agree^^^
Many Schit Daily
F-2 Speedy 06-22-2018 11:38 AM
does it have the 50amp red reset button back by the dist ?? cant remember if it will crank if this is tripped ?? popped breaker fuse on the starter that sends power up top ?
