-   -   low on power any ideas? (https://www.offshoreonly.com/forums/general-q/354746-low-power-any-ideas.html)
mira boater 06-18-2018 07:05 PM
i have a baja 204 with a 5.7 it struggles getting on plane. I built the motor 2 years ago it has a comp 270 roller cam vortec heads edelbrock rpm intake 1409 carb 600cfm. The boat always ran great until i changed the upper gears i went from 1.81 v6 ratio and 23p prop planed great would run 55mph at 52-5300 rpm. I wanted to put the proper ratio in my drive hoping for some more speed. Now with 1.51 ratio and a 21p mirage prop it struggles to plane and when it does the motor will only rev 4400rpm at 55mph any help would be greatly appreciated
Griff 06-19-2018 02:17 AM
You need drop down to at least a 19" prop with that much gear ratio change. Probably should have just left it the way it was.
