-   -   Easy 100HP Gain on 6.2 MPI... (https://www.offshoreonly.com/forums/general-q/354763-easy-100hp-gain-6-2-mpi.html)
MR.HAPPY 06-19-2018 09:34 AM
Hey Guys? What's the easiest way to get another 100 hp out of a 6.2 MPI 320 hp?
GM is get'n 420 hp in their Silverado with the 6.2 & I'm sure its not on the edge...
Do any of these programers that are available for the 6.2 MPI ready work & are they safe?
Thanks!
COOPS 06-19-2018 09:44 AM
Different engines, same displacement.
SS496 06-19-2018 11:05 AM
^ x2
SBC vs. LS
Baja Rooster 06-19-2018 11:17 AM
No such thing as an easy 100hp.
Crude Intentions 06-19-2018 11:20 AM
Supercharger
phragle 06-19-2018 12:38 PM
Cam, heads and a blower.....
Baja Rooster 06-19-2018 12:56 PM
...and new fuel lines, oil coolers, thermostats, cooling, exhaust...
BUP 06-19-2018 05:41 PM
will not get there with stock exhaust set up and that is correct the 6.2 Merc offering is not an LS version like whats in the GM truck / SUV side. / Sport car side. Its just another out dated engine making way less than 1 hp per cubes like many of their black side marine engines.
So many other Marine manus have moved on from that out dated platform. You have Indmar and pcm making over 550 hp with a small blocks and Ilmor as well. Volvo 430 hp with their small block set up.
phragle 06-19-2018 06:39 PM
Yes sir, who ever it was at merc that vetoed moving into the LS series needs to be ***** slaped forcefully about the head and shoulders, its cost them a lot of market share.
MR.HAPPY 07-18-2018 09:30 AM
So... it will take a 383 build then you're saying...
Then 450 hp would be easy...
