-   -   502 MAG EFI build reccomendations (https://www.offshoreonly.com/forums/general-q/354868-502-mag-efi-build-reccomendations.html)
PA.WOODCHUCK 06-22-2018 06:45 PM
As a winter project I may do a refresh along with some updates. Besides the normal checking everything over, replacing as needed what cam is best to use and what were your good/not so good results. Presently thinking of stock exhaust but that may change too. If so what is a good choice without breaking the budget. Spent the last 20+ years with outboards and getting back to I/O's
thanks
Baja Rooster 06-22-2018 11:14 PM
The bottom end is pretty stout, so the popular mods of new heads, 525EFI cam, and some good manifolds will wake her up and rectify its weak link (heads) in the process.
PA.WOODCHUCK 06-23-2018 01:21 PM
What's the difference in the cams? Do you have the specs on both?
What are the choices for manifolds and heads or is manifolds just enough?
What would be end performance gain?
Ryan00TJ 06-24-2018 09:45 AM
thanks
Contact some engine builders that advertise here on OSO. They have proven packages. You'll also need them to tune your setup when complete. What HP goals? Budget? The MPI intake/TB gets very restrictive at 500+hp. Stock exhaust is crap.
