-   -   Thermostat Yes or No (https://www.offshoreonly.com/forums/general-q/355028-thermostat-yes-no.html)
RBeyer 06-29-2018 10:54 PM
525SC Carburated with crossovers, is there any need to have thermostats? if so why.
RBeyer 06-30-2018 12:58 PM
The reason I ask is I have had a problem out of nowhere. I have newly built motors. After about 15 hours and after boating for a few hours one dayhttps://cimg3.ibsrv.net/gimg/www.off...a6b7c2ef37.jpg
my starboard motor after getting back on plane after a long channel ride started to get warm just at 200, when back to idle it started to drop.
We have replaced all of the somewhat antiquated cooling system with all new Merc stuff and hoses. The old sea water pumps did show wear but the impellers were intact. The motors have crossovers and the Stainless Marine T-Stat adaptors. I really don't know if it has T-Stats but I'm guessing yes that cruising is at 150 degrees, I'd like some other thoughts before taking it apart and possibly removing them.
Other than the temp rise it runs great. I really cant water test at the moment because we are still in a closed no wake scenario because of flooding. I was hoping to get this complete before reopening.
Crude Intentions 06-30-2018 01:31 PM
New exhaust? Could be a blockage anywhere. No matter how new impellers are they can't be ruled out either. If there are stats that one could be failing not letting it open all the way. Just a couple ideas.
RBeyer 06-30-2018 01:40 PM
I bought the boat in December all are very reputable builder, seller etc. much history on boat. I'm not sure if exhaust is new but looks it and operates as it should. The old water pumps were replaced and worn but both impellers were intact. We may already have this fixed, I was just thinking that since I can't boat and really not water test that I may check that as well. Because of it being a blower motor and with crossovers if it does have T-stats does it even need them and if I take them out am I causing another issue?
Baja Rooster 06-30-2018 01:42 PM
Do you have water pressure gauges? Can you see any difference in volume of water coming out?
Crude Intentions 06-30-2018 01:46 PM
no thermostats or restriction can be a problem as sometimes water can flow to freely not adequately cooling. Plus you want some temp the motor. 140-150 is good but it needs something. I only asked about exhaust as older stuff can be blocked also.
RBeyer 06-30-2018 01:47 PM
Does not have pressure gauges and it looks like all is equal now. I did not check that before we tore into the raw water pumps. Like I said it ran great for about 15 hours before I had any issue. We replaced hoses pump assemblies, made sure all hoses were clear. All headers seem equal temp. It may be okay now but trying to chase down everything since I can't boat anyway.
Sonic Steve 07-02-2018 02:25 PM
If your boating on the Chain it’s possible you sucked up some silt, you may want to check your blocks periodically and open up the drain plugs and see if the water flows out cleanly.
RBeyer 07-04-2018 11:56 PM
Still climbing temps under power, it immediately drops at idle, I'm thinking because of bypass holes in T-Stat. Changing thermostat and will drain down blocks to make sure they run clean. I will post results after.
RBeyer 07-06-2018 11:59 PM
Just a sticking T-Stat. Running great. Upgrading and replacing old raw water pumps and hoses although maybe not necessary didn't hurt.
Thanks for the input.
