-   -   Carb to EFI swap on 525sc?? (https://www.offshoreonly.com/forums/general-q/355049-carb-efi-swap-525sc.html)
RollWithIt 07-01-2018 10:45 AM
Sorry if this is in the wrong section. Just wondering if anybody has ever swapped out the carbs on a 525SC for an EFI unit? I have one carb that is dumping fuel at lower RPMs and hoping a simple cleaning with minor adjustments will fix the issue vs a rebuild. So I am naturally wondering if a switch to fuel injection would be possible.
glassdave 07-01-2018 06:40 PM
gonna be watching this one :cool: i often thought one of the FI-Tech or FAST systems would be a cool fit on that engine (provided its possible)
delsol 07-01-2018 10:45 PM
Don't see why you couldn't throw Holley throttle bodies on top pretty simple install...
MINK 07-02-2018 01:33 PM
Carb rebuilds are cheap fyi..
SB 07-02-2018 01:36 PM
1st carburetor my wife (early on while we where dating) learned how to rebuild was a Factory Merc Dom from a 525SC. I did one while she followed along on the other,
True story,
Holley's are the easiest thing to rebuild out of all carbs and fuel injection,
RollWithIt 07-02-2018 08:30 PM
I'm glad to hear that rebuilds are cheap and easy. Was just wondering if anybody had done a conversion since you see it all the time in the automotive world.
tmmii 07-02-2018 10:06 PM
Would think for he money you could change out power valves to 2.5 or 3.5 and take care of the idle loading up issue and save yourself a few thousand and have less stuff to break. That being said I love efi, but there comes a time when you are throwing good money at bad.
Griff 07-02-2018 10:46 PM
I've never heard of anybody doing it. It sounds like you've got a bad powervalve or needle and seat assembly.
Other than having to let it idle at 1000rpms for 1-2 mins on a cold start, mine idled and ran like an EFI.
Bump your neutral idle speed to about 800 rpms and play with the idle screws.
BBYSTWY 07-03-2018 06:49 AM
holley just released a new EFI setup for supercharged applications....they don't have it set up to run dual throttle bodies yet which is why I haven't considered it...however in a single carb application like yours it looks to be the most reliable and inexpensive by far...you do need a dry section of exhaust however to run the O2 sensor....but it is self tuning and looks like a breeze to setup...haven't seen one but have seen automotive holley efi add ons and if it were me that would be my choice hands down
Sydwayz 07-03-2018 08:30 AM
Hey Jason, Mark Rinda at MER in Myrtle Beach has done quite a few Holley setups. He would be a good one to ask.
https://www.facebook.com/pages/MER-Performance-Marine
Baja Rooster 07-03-2018 10:43 AM
I hate carbs, but tuning a Quickfuel with a wideband has been quite tolerable, and wouldn’t want to run without a wideband again. I had plans of switching it to something like a Holley Sniper but I haven’t heard any case examples of it either way.
BBYSTWY 07-03-2018 10:52 AM
https://www.holley.com/products/fuel.../parts/550-513
1500 bucks...done
Baja Rooster 07-03-2018 11:09 AM
Originally Posted by BBYSTWY (Post 4635606)
Ive heard they work well on SC applications such as this. A little too restrictive for NA for anyone wanting to go that route.
SB 07-03-2018 11:46 AM
You have that mixed up. Draw thru is not like blow thru with various things.
hogie roll 07-03-2018 11:54 AM
800cfm main body. It shouldn’t hurt a stock 525sc much or at all but if you turned it up you’d probably be giving up hp over a big dominator or big TB.
RollWithIt 07-03-2018 07:41 PM
That Holley setup looks nice. But at 1500 times 2... I'm sure the needed adjustments I'm looking at now would be cheaper. But, It is something to consider if or when I would need to replace the carbs...
Griff 07-03-2018 08:47 PM
The 525SC supercharger also have 4500/Dominator carb bolt patterns.
ezstriper 07-06-2018 05:51 AM
couple of things...EFI and cheap do not go well together, find a place to a get a 02 to live is another major feat(trust me on this one) and last they make it sound plug and play simple, sometimes it does turn out that way..sometimes far from it...
Baja Rooster 07-06-2018 01:10 PM
Thats just the beginning of my mix ups, lol.
FI is advancing pretty quickly these days. Add an O2 sensor with a wideband to sort out the carbs, and then if the sensor survives it’ll possibly be an easier upgrade to FI.
SB 07-06-2018 02:22 PM
The more someone depends on the ECU to make the correct decisions when tuning, the more their chances of fking themselves up the azz at some point.
Accountants learn how to do accounting before using the computer to help do so.
