HP500 backflush
Does anyone have instructions on how to backflush a HP500? I think you disconnect the oil cooler hose and run water through there but not sure which hose on the bottom to disconnect to let the water flow out. I tried searching for a water flow diagram but couldn't find one.
Thanks! |
The hose goes from sea pump to oil cooler. Pull both ends of this hose and flush it. You can also pull cap on cooler and make sure no pieces/debris are in there |
Originally Posted by Crude Intentions
(Post 4636589)
| All times are GMT -5. The time now is 08:29 AM. |
