-   -   Why not use newer version (clearance on one side) gimbal bearing in older drive? (https://www.offshoreonly.com/forums/general-q/355369-why-not-use-newer-version-clearance-one-side-gimbal-bearing-older-drive.html)
GrannySShifting 07-16-2018 10:35 AM
Not really sure why you couldnt if you werent sure which driveshaft/u joint assembly you had and if you needed the clearance just use the 98-up (or 2000-up depending on what you read) bearing? I have an older drive for sure serial 0F5, and one that is 0Lsomething. The first definitely didnt come with the offset side bearing, but i just pulled out two good shape sealed, offset side bearings from the looks of them.
So why not use Sierra 18-21006 (sealed offseet) on everything and be done with it?
