-   -   Trim issue (https://www.offshoreonly.com/forums/general-q/355406-trim-issue.html)
Franks292 07-17-2018 10:01 AM
Trim issue
Hey everyone, went out over the weekend and had an issue with my boat. I have a Formula 292 fastech with Bravo 1's. Long story short, the trim up on my starboard side engine does not work. And trailer up for the starboard side will only work when port side is all the way up. I was thinking a bad limit switch but why wouldn't the trailer up work all the time if that were the case? And what should I do to fix or bypass the issue? Trying to make it through the season without taking it in or making major repairs unless absolutely needed. Any input and solutions are appreciated. Thanks!
payuppsucker 07-17-2018 10:15 AM
If you have trim switches in the throttles find the point where those wires tie into the wires coming from your rocker switches. That is most likely where you'll find your problem.
Franks292 07-19-2018 10:19 PM
Bump
Griff 07-20-2018 12:44 AM
What you should do is take it into a tech who knows how to test everything with a volt meter.
