525 coolant cap leak
I have a coolant leaking from coolant cap on tank of my 2005 525. I pressure tested cooling system and holds 15psi with no leaks but when I run boat I get coolant coming out of cap puddles on top tank then runes down side of tank into bilge. I pressure tested cap and will only hold 4psi so ordered new cap and some thing happens. So I pressure tested new cap and it also only holds 4psi when cap says should hold 15psi. But here is real mystery the other motor does not leak even when I switch caps. Booth only hold 4psi when I test them. Temp runs fine but will slowly push out coolant through cap when running. I loose about a quart every 4 hours of running. I am thinking that cap should hold 15psi like it says and when engine heats up is slowly pushing pressure out loosing coolant. Anyone ever have this happen? Could it be caused by something else?
Do you have a crack in the neck of the coolant tank?
Have you pressure checked your heat exchanger by itself? |
X2 on checking the tank.
Head gasket leak causing the cooling system to over pressurize? Was the top end refresh done at the prescribed time? |
How does your coolant look? Quite possibly the heat exchanger leaking. When under way, the raw water will enter the closed cooling system and over pressurize it.
I did not pressure test just the cooler but that makes sense! Coolant does not look dirty or watered down but that really would be hard to tell just looking in tank. I will pressure test radiator see if can track down.
Some times some watered down coolant will drip out of the drive when you pull it out of the water
I will check that. Thanks
Well I pressurized heat exchanger alone and did hold 20psi. But I have 40 plus psi water pressure when running hard. I pulled plugs did leak down test on engine no signs of head gasket leaking. I guess I am going to order new heat exchanger and see if it fixes issue. 1k gamble but sick of screwing around with this.
Did you check the tank for cracks yet?
Yes, I pressure checked and inspected no leaks. The coolant is coming through cap that I am sure of.
Sealing surface for the cap OK?
Where the gaskets sets? Flanges and locking notches and tabs deformed at all? Radiator shop can probably repair if needed. $1k... |
I have had them repaired at a radiator shop as well. Does it only do it when on plane? Never does it sitting still?
The top flange on tank is little rough and was a concern that not getting good seal but it did seal good when I used my pressure gauge. Think it would help to double up rubber seals on the cap?
Originally Posted by rvtransport
(Post 4639970)
When you originally psi tested your closed cooling system, you connected the correct cap onto your expansion tank and pressureized to 15psi? No leakage or drop in psi? This tells me the problem is not in the closed cooling system. |
No I pressurized system via removing cap and pressurizing the tank. I never thought of rigging up a way to pressurize system with my cap on and seeing if I can get the cap to leak. There is a small hose that runs from tank to top of heat exchanger wondering if I cap one side then pressurize through hose would work?
(Post 4640011)
I found the problem. The top tank is leaking around surface where cap seals. When I use my tank pressure adapter and regular radiator cap it hold pressure. When I put cap on I can hear it leaking around seal. I am going to run it this way temporarily until I get a new cap. Thank you guys for helping saved me 1k for new heat exchanger!https://cimg8.ibsrv.net/gimg/www.off...beb958578.jpeg |
Congrats
| All times are GMT -5. The time now is 08:15 AM. |
