-   -   How restrictive is stock 502MPI Exhaust? (https://www.offshoreonly.com/forums/general-q/355977-how-restrictive-stock-502mpi-exhaust.html)
Swamplizard 08-11-2018 01:57 PM
Engine room is super tight and though I like my Gils they are literally touching in twin engine bay- can someone compare difference in flow between Gils and stock Merc 502 MPI manifolds?
at what HP does it start to matter?
Thanks!
Griff 08-12-2018 12:45 AM
The Gils are probably adding 10-15hp on stock 502 mpi's.
NHGuy 08-12-2018 07:50 AM
I'm not a twin engine owner but want to know about "stuff"
Touching won't last. Could you put a wedge gasket under the Gils to tilt them a bit? Or a thin exhaust gasket? Or both.
You probably can't tilt the engines on their mounts without throwing off their alignments to the transom plates.
I'd put up a lot of fight for 10 or 15 horsepower.
Griff 08-12-2018 01:04 PM
10-15hp per engine in his boat is prob only a 1/2 mph on top end
Swamplizard 08-12-2018 01:28 PM
not even Grif - but if I put a blower on it ;-)
looking at a pair of stock 502MPIs which come with stick exhaust - I already have Gils in the boat.... so thought I ask.
