1985 scarab 1 holding water and gas
I am restoring a 1985 Scarab 1 21ft and I was removing the built in Ice chest in the cuddy cabin and between the beams was a mixture of fuel and water.
Currently I'm doing a pressure test on the 60 gallon tank and it is holding , however I think the the fuel filler hose was the where the leak has been and possibly the fuel line from the tank to the engine. I am trying to find a hull drawing and drain port location and routing. It's a nice boat only 451 hrs on the 350 Mercruiser. Any ideas ? I've called Wellcraft and no response ! Help . Thank you, Spyke |
I am trying to find a hull drawing and drain port location and routing. Drain port, for What,..?? Hull drainage should be through limber holes in the stringers, 'n bulkheads, leadin' to the pumpable bilge,..... |
| All times are GMT -5. The time now is 10:12 AM. |
