Gen 5 & 6 Thermostatically Controlled Engine Block Adapter
In regards to the Gen 5 & 6 Thermostatically Controlled Engine Block Adapter, do I still want to use the 30lbs bypass in the block. I have heard no and also yes anyone using this now did you keep the bypass? I will be using -12an line from adapter to remote oil filter and to the cooler.
Regards, Steve |
Regardless of oil cooler or not I’ve only seen encouragement to remove the center one and block off the outer with a small freeze plug. |
Yep that's one of the opinions I was told also.............
| All times are GMT -5. The time now is 08:53 PM. |
