-   -   How many GPM is a Gen 7 sea pump? (https://www.offshoreonly.com/forums/general-q/356284-how-many-gpm-gen-7-sea-pump.html)
axm0z5h 08-27-2018 06:55 AM
Im looking to see how many gallons per minute a gen 7 sea pump is to make sure its sufficient for the closed cooling system i installed this week.
underpsi68 08-27-2018 07:44 AM
Almost a gallon a second at speed.
axm0z5h 08-27-2018 07:56 AM
That should work for my application then. The heat exchanger said it needs 35gpm. for some reason the engine is overheating. I rebuilt the sea pump, put in the ss wear plates and new impeller. Im just trying to narrow down what could be causing this
Keith Atlanta 08-27-2018 08:57 AM
Try the power steering cooler. Pull and clean it out.
underpsi68 08-27-2018 12:36 PM
The p/s cooler on my 496 was a straight through design. The oil cooler would collect all the debris.
axm0z5h 08-27-2018 12:44 PM
i put the hose directly into the sea strainer and my issue went away. Looks like the issue is the hose in the transom assembly. im going to install a thru transom water pickup tonight.
