Boring 454 Mag
How far can a 454 Mag be bored?
depends on whats left of the block.
Depends on what Gen and how thick the block is. The older MK4 could go bigger. Gen 5 & 6 are maxed at .060 and lot them can't even go that far.
some of the MK4 blocks are pretty done at .060 depending on the casting number and core shift. some are fine at .070 or so and the older 512 casting numbers are fine at .100 over if they dont have a core shift issue. seems like the later of the MK4 blocks were when they started getting thinner but not positive of that.
Thanks all it's a 98 motor and already at .060 I figured the block was probably done.
I ran a Gen V .070" over (4.320) for 13yrs up to 600HP at @ 6500 at a times with no issues. The engine was built at 420HP by someone else 6yrs prior to me. Not recommending it without the block being checked, but I have done it.
Originally Posted by Rookie
(Post 4646017)
Originally Posted by RBeyer
(Post 4646018)
This motor would be around 800+ HP Just looking at an old project boat and adding the $$$ up. Ahhhh Toys!
Why not look for a used block on Craigslist. |
Originally Posted by Craney
(Post 4646028)
Have the bores Nicosil plated to bring back the tolerances. Look into US Chrome for the process.
(Post 4646017)
I'd definately only go as much as needed if your going SC cause of the heat. Like rookie said sonic testing each bore will tell the tale. Fresh water blocks vs salt water blocks can be night and day difference. |
Read this before you decide what your going to do
http://Garage.grumpysperformance.com...ck-cylinder-wa |
| All times are GMT -5. The time now is 11:16 PM. |
