-   -   I need a Holley carb expert (https://www.offshoreonly.com/forums/general-q/356426-i-need-holley-carb-expert.html)
snapmorgan 09-03-2018 08:11 PM
Just put the engine back in my cat after a couple of upgrades. 565CI/420blower/ Ken Jones 830CFM carbs. Freshened it up, installed a MSD crank trigger and daytona igniyion. Had it out saturday and all was good for the first 3 hours, never saw over about 4K rpm and 3# of boost. AFR's were around 14 at idle and 12-1 while running. All of a sudden it coughed and hiccupped once and went lean. 20-1 at idle, 14-1 running. Fuel pressure is 7.5# at the fuel rail. I have a large spin on filter right before the carbs. All 4 bowls are fuel of fuel, float levels checked, all 4 squirters working. I removed all 4 bowls and metering blocks, all are squeeky clean. I was doing all of this on the water, so resources were limited, but I see nothing wrong. Is it possible that a power valve can just stop opening and cause this? These have boost referenced power valves on the primaries, not that it really matters. I guess another option could be a huge vacuum leak, but I can't find one. The hoses to the carbs, MAP sensor and boost guage are all connected. I guess it could have blown an intake gasket, but I really don't think so. I used the good Felpro gasket with the silicone inpregnated on it, and again, never over about 3# of boost although I was about to let her rip, I hadn't yet. Any ideas?
GLENAMY 242SS 09-04-2018 07:51 AM
Just a stray guess, but, have you checked the vacuum port on the base of the carb. I believe it originally connected to the choke.
Hope you find a simple solution. How did it run otherwise?
Good luck.
PS, I am not a Holley expert.
snapmorgan 09-04-2018 08:09 AM
yes, all vacuum ports are still capped. The more that I think about it, the more that I think it must have blown an intake gasket.
snapmorgan 09-04-2018 08:13 AM
Other than that, It ran better than expected. Idles at 800rpm, 600 in gear, no blower surge. The combination of the Daytona Sensors ignition with a crank trigger is the ****z on a carb blower motor. It even got on plane just fine with 1.36 gears and a 30" prop.
mike tkach 09-04-2018 08:23 AM
where are you getting the vacuum for the boost referencing?
snapmorgan 09-04-2018 08:38 AM
right off of the back of the intake manifold
snapmorgan 09-04-2018 08:43 AM
Boost guage, map sensor and power valve lines are all T'd in at the same place. I wonder if I can introduce a little propane into the crankcase and listen for the engine to pick up or watch the AFR guage and either verify or rule out the intake gaskets. I currently have around 8" of vacuum at idle.
mike tkach 09-04-2018 08:49 AM
that is how i do it.did you put a smear cote of sealer around the ports on the gasket?i don,t rely on the print o seal on the intake gaskets because i have seen them leak.
snapmorgan 09-04-2018 08:52 AM
I only put a little sealer around the water ports, not the intake ports
SB 09-04-2018 01:09 PM
Most carb issues I fix are lean issues from blockage.98% of the blockage's I never see. Using the red straw with your carb clean in both directions of every circuit and then using a rubber tipped blow gun from yourcompressor both directions has removed any non visual blockage I'n run into other than mouse pee eroding the aluminum enough to shut some air bleeds :( and small pieces of fuel line rubber lodged in frt of or in the needle and seat,
i too use propane to look for vacuum leaks. Unfortunately alot of vacuum lines and plugs immediately disintegrate with carb clean now. :(
