-   -   distributor rotor not turning 525sc (https://www.offshoreonly.com/forums/general-q/356488-distributor-rotor-not-turning-525sc.html)
az242ls 09-05-2018 08:51 PM
525sc motors. Roughly 100 hours
Running 4000 rpm last weekend port motor shut down would not start up again. Trailer ed it home.
Tonight turned it over and saw all the rockers moving. Pulled distributor and roll pin is still in tact.
Turned it over while looking down the distributor hole and could not see the cam gear moving.
What am I looking at here? broken cam?
thanks in advance
SB 09-05-2018 09:09 PM
Sounds like it,
Crane had a bad large batch of hyd roller cams years back that did this, but I have not heard of a flat tappet cam (525SC had hyd fat tappets) doing this, but I guess anything is possible.
getrdunn 09-05-2018 09:13 PM
X2. That sucks. I Remember the same deal for a certain period of time.
phragle 09-05-2018 09:27 PM
perfect opurtunity to upgrade the cam and valvetrain !
Griff 09-06-2018 01:32 AM
A broken cam is the only thing that would do what you describe. Never heard of it happening on a 525SC though.
az242ls 09-06-2018 09:09 AM
SB - i have crane roller cams on these engines
BBYSTWY 09-06-2018 10:01 AM
If the cam is rolling and cycling rockers but the cam gear isn't moving....only one thing that can be...bad cam....its possible I guess if the cam gear is pressed on that it could have came loose and is slipping...however regardless the cam needs to come out IMO
F-2 Speedy 09-06-2018 10:34 AM
looks like SB nailed it...........btw ^^^^^^the gear is machined into the core
az242ls 03-30-2019 10:36 PM
update
Cam was broken in Starboard engine. - sent them down to Larrys Engine and Marine in Tucson, AZ. did Both Engines and completely.
dykstra 04-02-2019 08:08 AM
Thanks for the update. It’s frustrating when someone starts a thread about a problem they had and forget/neglect to let everybody know what the outcome was, so we can learn from it.
Im glad you got it sorted out!
Come on summer!!
dykstra 04-02-2019 08:11 AM
Starboard? I thought the problem was in the port motor? Glad you got it fixed.
