-   -   Storing batteries for the winter? (https://www.offshoreonly.com/forums/general-q/356722-storing-batteries-winter.html)
Camalot 09-18-2018 04:30 PM
We winterize around 200 boats here in Canada and never take the batteries out just disconnect after we have finished.
Rookie 09-18-2018 07:47 PM
I pull all of my batteries from my boats (4) and put them into my solar grid system and maintain the 13.2v-13.8v float charge that is recommended. (from the charge controller) They also see some cycling when out in my building.
ALL_IN! 09-19-2018 10:16 AM
I corrected your spelling....
Originally Posted by ezstriper (Post 4649703)
..., if you remove them the old saying(my dad swore by it) DON'T let sit on concrete is been proven not true.
And you are correct, storing on a concrete floor does not hurt a modern sealed battery that is in, otherwise, good condition.
SFOcean 09-20-2018 12:45 AM
Originally Posted by Baja Rooster (Post 4649781)
I live in California. What is this “winter” that you all speak of? :p
This would be the time to 'winterize' which means getting a windbreaker out of the closet.
Sydwayz 09-20-2018 09:31 AM
I don't like keeping them on concrete for temperature reasons. Keeping them elevated keeps the temperature more uniform from bottom to top. I don't have radiant floor heating, but that would be a different element.
_therealmattyice 11-27-2019 03:08 PM
Originally Posted by Sydwayz (Post 4649546)
Back when I had a boat that the batteries were easy to pull, and the boat was statically stored outside; I would pull them and put them inside stored on wood, (not on concrete) with trickle chargers attached. The last few years, I have just left them in the boat, and plugged the boat in for about a week a month to keep them topped off.
I know I am bringing up an old post, but I've pulled my batteries from my Donzi and am storing them inside for the winter.
Which charger would you recommend? ..Pulled them around end of October and they have been sitting in my guest bedroom since. Interstate Deep Cycle Marine/RV. I know I need to get something hooked up to them to maintain until spring.
-Matt
cigrocket 11-27-2019 03:38 PM
I have one of these mounted in my Garage. Charges the boat batteries and my summer car battery. Easy, plug em in and forget it.
Ryan00TJ 11-27-2019 03:44 PM
https://cimg7.ibsrv.net/gimg/www.off...99acc75723.png
Have used this model for years with no problems. We use the larger 48vdc model for batts at work with same success.
thirdchildhood 11-28-2019 04:51 PM
I live in Michigan and bring both boat batteries, 3 Mustang batteries and the lawn tractor battery into the basement every winter. I don't know if it helps but I usually do get a long life out of batteries. I also keep them elevated and off the cold floor and put a slow charge into them about twice over the winter. lol, just realized that I answered this thread over a year ago!
flashgordon 11-30-2019 09:40 AM
hello,,yes i am also in the lovely state of michigan, for years i use to always bring batteries home , put in basement on a peice of wood, then trickle charger them. but now keep current boat in my heated garaqge year round, so just leave batteries in boat and trickle charge them every 3-4 weeks.
if your boat is sitting in a boat yard, i think i would still bring them home, as you couldnt charge them in a yard.
