Alum heads in Saltwater & closed loop cooling question ??
I'm looking at purchasing a boat with a fresh, mildly build 500 EFI w/aluminum heads. My usage would be approx 1/3 saltwater & 2/3 freshwater.
Something about dunking an aluminum head motor in the salt just gives me a bad feeling...dissimilar metals and all of that. Even though aluminum is more corrosion resistant on its own, I'd almost feel better dunking an all iron engine....but maybe I'm off base, since i have no experience with aluminum heads in salt. - How would you feel about running an aluminum head engine in saltwater, knowing your were going to give it a good long flush afterwards with fresh water and salt-away? - How effective are aftermarket closed loop cooling systems like this? - https://www.hardin-marine.com/c-1527-complete-closed-cooling-kits.aspx Anything to watch out for? On one hand it's not rocket science....on the other it would be nice to know it was a proven set-up with proper thermal capacity, flow rate and thermostat temperature, etc. (i.e wouldn't want the thermostat to restrict flow rate when engine was cold, increasing chance of detention, etc. - If the engine was tuned with raw water cooling, is switching to closed loop going to present any problems? Thx. |
There are no negatives to FWC . As long as you have an appropriate sized heat exchanger you're fine. As far as 'tuned for raw water cooling' goes the only real difference is that the thermostat is generally set to open a few degrees warmer on a FWC engine. Of course, understand the difference between full FWC and partial/half FWC.
Even if you had an engine with no dissimilar metals in its build , all iron or (heaven forbid) all aluminum , and you boated in fresh water there's still nothing but positives . And don't forget , if you're in a location that falls below 32f in the winter winterizing is much easier. If you poke around on here you'll see stories of people who had , as an example , stock 502s (that have alloy intakes) that they flushed religiously that still had intake manifold corrosion issues. |
Here is an aluminum intake that was on my 525SC https://www.offshoreonly.com/forums/...sc-intake.html
without antifreeze(w/rust inhibiter) in the cooling system aluminum parts will corrode badly...salt water just speeds that up.
Don't think you are in the clear just cuz you have iron heads and intake. #2-7 exhaust guide like to rot through on iron GM heads.
Would it be possible to do a full FWC system if the engine has and EMI thunder exhaust, extended to dry tails?
I just put aluminum intake and heads on my 383. I installed three of these. One in the intake and one in each head. My boat is a fresh water only.
https://www.summitracing.com/parts/f...waAj-vEALw_wcB |
What is everybody thoughts on AFR heads with the hard anodizing in saltwater? |
Hard coat anodizing does a great job of resisting corrosion.
Especially done right. Edelbrock sells some heads you could buy with coating. https://www.summitracing.com/parts/EDL-61459/ You have to prep if taking existing ones and coating them. Need to apply block off to keep it out of tapped holes or tap oversize before hand. Do any machining before. Don't let it get applied to dowel holes. Always been surprised not more done for marine applications. |
Originally Posted by Craney
(Post 4651070)
Originally Posted by Paxtonspeed
(Post 4651009)
https://www.summitracing.com/parts/flx-32060?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-flex-a-lite&gclid=Cj0KCQjwuafdBRDmARIsAPpBmVWtCnPHAKek4VV oWeluqupOYbPS0-wYkZ6sUHqPNVVifcKMyX9h16waAj-vEALw_wcB https://www.defender.com/html/zincs_info.html |
(Post 4651070)
That’s good to know. |
Originally Posted by Rookie
(Post 4651146)
Those are a good idea, but just a heads up, for fresh water you want the Magnesium pencil anodes. Zinc is better than nothing I believe.
Ryan - you used anodes for the heads/intake on the 383 / I don't remember this.
Originally Posted by SB
(Post 4651178)
Originally Posted by Ryan00TJ
(Post 4651167)
Yup, Zinc for saltwater. Mag for fresh. Zinc will do virtually nothing in freshwater. The bare aluminum will become your sacrificial anode. FWIW My 1992 AFR heads were still going strong in 2014 when I sold them. Freshwater use. Once you go closed cooling you'll never go back!!
"Flex-A-Lite developed these zinc anode kits to be installed as a replacement for the drain petcock in radiators equipped with a 1/4 in. NPT bushing welded into the tank (they can be installed in any 1/4 in. NPT hole that is available in the cooling system). For years anodes have been used in heavy-duty and marine applications to protect the cooling systems and its many components from damage due to electrolysis. Flex-A-Lite now brings this protection to you. Today's cars and trucks have many aluminum parts and parts made in combination with aluminum alloy. Aluminum parts may disintegrate from electrolysis in the cooling system. Installing a Flex-A-Lite zinc anode will protect your cooling system from galvanic action by "eating" the zinc rather than your cooling system. Cheap, effective insurance." I just pulled the intake, to do a cam swap, I also pulled the anode to see what it looked like. The anode already had a noticeable corrosion on it. The aluminum intake and heads showed no signs of corrosion, just a little brown staining from the lake water. I needed the plugs anyway, so I figured what the heck. |
Asking again - Would it be possible to do a full FWC system if the engine has an EMI thunder exhaust, extended to dry tails?
Originally Posted by motuman
(Post 4652717)
| All times are GMT -5. The time now is 05:23 PM. |
