Gen 6 502 over size pistons
I have a chance of getting my hands on a Gen 6 502 which had a riser gasket fail with low compression in two cylinders for cheap, looking around for pistons I see they only make 4.500 as the next size. The only play I find a .030 over is GM Performance which is a little pricey :)
Could anyone advice me if this is the only way to go and can the Gen 6 be bored out to 4.500 with no problems? Thanks in advance |
Sorry guy's I was looking at the wrong spec sheet lol I see stock bore is 4.465.............opps
many things can cause low compression, it may not even need bored, have you pulled it apart ?
4.47
(Post 4651232)
Originally Posted by GPM
(Post 4651238)
4.47
JE makes a set .002 oversized. If everything else is good you can get away with a good honing with torque plates and be better than new. I’d still lean towards boring it out though as the expenses for parts are the same. http://www.jepistons.com/Catalogs/SR...placement.aspx |
| All times are GMT -5. The time now is 07:14 AM. |
