Metal in Heads..Where Could It Be From? >
Old 10-21-2018, 12:59 PM
Comp Cam
Have a lot of high quality parts in the motor, but from what I have read here, Comp is not the cam you want
AllDodge is online now
Old 10-21-2018, 01:02 PM
BUP
any oil pressure issues ?
inspection of the roller rockers ?
compression solid
I know your not a stock app so asking about the inner spring / valve springs ??
BUP is offline
Old 10-21-2018, 01:05 PM
BUP
Merc stock lifters - I would take a look at these under close inspection
BUP is offline
Old 10-21-2018, 01:10 PM
BUP
He reports the cam is from cam motion -- they are in Louisiana
BUP is offline
Old 10-21-2018, 01:32 PM
Your always quick on the trigger
See post 4 mentions both
Sorry, my bad, still think Griff has the answer
Old 10-21-2018, 06:49 PM
Rage's Avatar
Thanks to all for taking the time to share your thoughts. I found the culprit. I knew that the PAC beehive valve springs rotate above a certain rpm. The spring rotation speed increases as rpm increases. In past inspections I noticed a light polish where the spring contacts the retainer. This time I found scoring on most of the retainers from that spring contact/rotation. That is where the metal came from. I will be talking to PAC about this.
Rage is offline
Old 10-21-2018, 07:35 PM
Rookie's Avatar
Received 1,069 Likes on 519 Posts
Why are you running beehive springs?
Just curious
Rookie is offline
Old 10-22-2018, 04:43 PM
Rage's Avatar
Just curious
To reduce dynamic valve train weight so as to increase rpm threshold for valve toss. Smaller valve spring retainer and spring coils at valve tip end versus straight coils and multiple coils.
I ordered tool steel retainers to replace the chrome moly retainers that were producing the metal.
Rage is offline
Old 10-22-2018, 06:29 PM
I had the same issue. Turned out, the shop that put the heads together, didnt use the correct hardware, for the springs. The locator shoulder measured like .680, and the inner springs ID measured like .740 if I recall. The retainer fit also wasnt the best. The springs were rotating, and digging into the locators, leaving tiny metal specks in the heads where the oil pools. Also, the inner spring was rubbing on the stem seal, likely from the pizz poor setup. Springs had good pressures, around 180/470 when tested, but were the wrong springs. They were a mile away from coil bind. Probably surging, wobbling, and dancing all over the place. Lesson learned with that shop.
MILD THUNDER is offline
Old 10-23-2018, 10:48 AM
Rage's Avatar
Thanks for sharing that. Identical condition to my retainers. PAC recommendation for 0.080" coil bind clearance was followed. The beehive allegedly has some inherent surge damping because of its range of spring coil diameter and spacing. Did you see any evidence on valve stem tips or rocker arm rollers that indicated valve train instability?
Rage is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell or Share My Personal Information -
Copyright © 2023 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
