-   -   V Band Connections with Wet Exhaust? (https://www.offshoreonly.com/forums/general-q/357571-v-band-connections-wet-exhaust.html)
liquidlounge 11-08-2018 12:11 PM
I am assuming V band connections on wet exhaust will work fine? I have a relatively complex side exit exhaust set up (inboard mufflers, H-pipe, switchable exhaust); love the sound, but dismantling the system for any reason is like going through a back to back MMA match . I think a couple of strategically placed V band connections in the system will make things much easier to disassemble should the need arise. It looks as if various gaskets can also be used if a watertight seal is not achieved. Anyone have any knowledge or experience for this application? Any reason not to try?Thanks in advance!
sailtexas186548 11-08-2018 12:42 PM
Dry joint with jumper hose should work. Although a double oring groove and wet joint could be done if you have the machine/weld skills.
i would at a minimum run v bands with an oring on the sealing face
liquidlounge 11-08-2018 01:05 PM
Dry joint definitely not in the cards...running silent choice / short riser.
