-   -   Alternator Fused? (https://www.offshoreonly.com/forums/general-q/357796-alternator-fused.html)
ttrm007 11-23-2018 02:12 PM
Alternator Fused?
Working out the details on a few big items.
Charging System:
I'm taking a 4awg wire from my alternator (1 wire 105 amp) to positive of battery. Do I need / want this to be fused? Maybe something like this?
Trim and Drive Pumps:
Not sure what gauge wire yet? Probably just go with 4awg again? It his pretty big. Same question on the fuse.
Thanks.
ttrm007 11-23-2018 03:21 PM
Charging System:
I'm taking a 4awg wire from my alternator (1 wire 105 amp) to positive of battery. Do I need / want this to be fused? Maybe something like this? https://www.amazon.com/dp/B015ABMN6C..._t2_B06XW27WMD
Thanks.
Maybe this is better?
https://www.westmarine.com/buy/blue-...5?recordNum=44
Baja Rooster 11-23-2018 04:23 PM
Mercruiser uses this mounted on the starter, and yes you need one. My DB Electric alternator shorted and the starter and ground lugs immediately started to smoke (the previous owner removed the fuse). Had I not been right there the whole boat could’ve been a toasty puddle of burnt ash. It’s barely rated above your 105a unit so it may not be enough.
https://www.boats.net/product/mercur...saAuajEALw_wcB
F-2 Speedy 11-23-2018 04:26 PM
why are taking the output from the alternator direct to the battery, typically it goes to the starter + terminal where the battery hooks up, OE mercury wiring its orange
Baja Rooster 11-23-2018 04:52 PM
On a side note, 105a seems like a lot and requires heavier wires all around. I’m running three batteries with 85a and installing a charging isolator to ease the load a bit.
ttrm007 11-23-2018 11:37 PM
Ok so alternator to starter. Makes sense for a shorter run. Put fuse right on lug.
Thanks!
