I have extension blocks made in the past -- it all depends on the height needed. 2 in. thru 4 in.riser extensions is not uncommon for set up -- just depends on that set up for the needed height and of course room.
3 inch riser extensions seems to be the many on average Yes they can be expensive but cheaper than hydro locking engines and or rusting up many internals for engine failure. |
Those are some nice risers, Camelot! OP, given how sharp your current risers turn I’d go ahead and get new ones made anyways not unsimilar to what Camelot did. I believe Stainless Marine could do that for you, and while they’re at it get a couple O2 bungs welded in as well. Also pressure check the current manifolds to be sure that you’re not wasting you’re time and money. |
