New cam setup
Have a question it’s to late because I already made the choice and built the motors with this. But I’m reaching out to see what everyone things of this cam selection. So I did what I’d call a mild engine build on my at one time stock 330hb 454’s. I did a 750 carb. Edelbrock performer rpm air gap intakes. Exhaust and cams. My biggest question is am I going to run into future problems with my selections. If so what issues do I need to look for or what can I do to avoid these issues. Here’s the cam kit I ended up going with. I am running a wet exhaust as well. I will try to post a pic of the exhaust. As I also have a question that I’m sure someone could help me with on how to dump water further back instead of right up front. Very new to the marine performance game appreciate all the help and possible step by step solutions.
This is a link to the cam kit I bought. http://www.jegs.com/i/COMP-Cams/249/K11-236-4/10002/-1 |
Here is pics of how the exhaust is currently done. What can be done to remove the possibility of reversion. How would I go about moving the water injection point. Help would be appreciated https://cimg1.ibsrv.net/gimg/www.off...08e86598e.jpeg https://cimg2.ibsrv.net/gimg/www.off...8c3285aa34.png https://cimg3.ibsrv.net/gimg/www.off...e97100ad46.png |
I'm not an engine builder, but it looks pretty mild to me compared to what I've run without any problems.
And that’s all I was trying to do. And then of course today I was just scrolling thru other posts and started getting worried that I was going to have issues. Just trying to have something mild but reliable. It’s just a little 89 Formula 272 Sr1. Not trying to get crazy but what a little performance upgrades. |
You should be fine. The risers have a tall bend, so reversion should not be a problem
What about water getting back in from the point it is getting injectected. Is that a possibility at all? Seeing that it’s at the start of the risers? |
Those are double walled risers. The water doesn't enter until after the bend going down and ust a few " before the 4" rubber hooks up.
I'm running Merc 496 Aluminum exhaust with a 288/294, Lift .585/.610, 112 L/S cam. No issues.
http://supernova19.com/11c780e00.jpg |
Originally Posted by f_inscreenname
(Post 4664057)
Originally Posted by Camalot
(Post 4664060)
Isn't it strange I was running a cam close to your duration's but less lift and I had reversion using the stock 496 risers lol. Nice healthy cam how is that working?
Edit: Also, I see f_inscreenname pic above has S pipes. These help stave off exhaust water reversion also. |
Originally Posted by Griff
(Post 4664041)
(Post 4664057)
http://supernova19.com/11c780e00.jpg That is a lot of duration for that amount of lift. Hows the valve train like those ramps? Damn |
This is my mark IV, 454, stroked and roller'ed to a 496. I have to say I didn't always build winners but I seemed to hit it right with this one. No reversion issues. Has a bit of a lope during idle but besides that.... Most everything is off the shelf. Open 118 heads but use +18 dome pistons making it about 9.5 to 1 so its even good with pump gas.
Build sheet >>>> http://www.supernova19.com/current_b...nova19_com.htm |
(Post 4664130)
this is my mark iv, 454, stroked and roller'ed to a 496. I have to say i didn't always build winners but i seemed to hit it right with this one. No reversion issues. Has a bit of a lope during idle but besides that.... Most everything is off the shelf. Open 118 heads but use +18 dome pistons making it about 9.5 to 1 so its even good with pump gas.
Build sheet >>>> Current Build Sheet SuperNova19.com |
Originally Posted by SB
(Post 4664076)
If one is measured at .004" and another at .006" you can't compare seat duration easily.
Originally Posted by ICDEDPPL
@.050??
Are you guys thinking this is to much cam? |
Originally Posted by Smoke eater
(Post 4664193)
http://supernova19.com/11c780e00.jpgThese elbows look like they would dump water in the motor every time you slow down.
Those aren't the ones in question though. Regardless just don't slow down. Hah. |
Most Eliminators have them.Hard to find another manufacturer that has more crazy power installed in their boats.
(Post 4664235)
(Post 4664193)
Are you guys thinking this is to much cam? (288/294, Lift .585/.610, 112 L/S cam.) your cam is just fine. |
(Post 4664269)
I quoted and was refering to Fingscreenname.
(288/294, Lift .585/.610, 112 L/S cam. |
Originally Posted by GPM
(Post 4664241)
I'm not picking on anyone, anything, just thinking if the riser was long enough to dump at the 90, reversion would be a non issue. I could be wrong.
You can see the angle better in this picture, https://cimg8.ibsrv.net/gimg/www.off...30abdf1aad.jpg |
(Post 4664381)
Being I have had the set up for 4 or 5 years now I can tell you there is no reversion issues. It has Merc 496 Aluminum manifolds and their SS risers. They are the tall of long version but that only means a 1/2" taller then the shorter ones. From there it all stays 4" and goes to the outlets in more of a pulled out "Z" pattern. In other words it don't double back on its self. All of it leans to the transom. It does have flappers on the tips. Nothing special but it works.
| All times are GMT -5. The time now is 12:53 AM. |
