LS Build: In Progress >
Old 01-19-2019, 09:21 PM
This manifold looks better but it’s got a cat in it I think.
hogie roll is offline
Ron Bown (02-02-2021)
Old 01-19-2019, 09:56 PM
Originally Posted by hogie roll
You aren’t making 625hp through that exhaust manifold. Dyno in marine trim and let us know. Needs real headers and then more cam.
I will concur with that. With dyno headers it will be right there. The marine power manifold is the exact same manifold as imco power flow from imco. Exact. If you look at a cutout of it you will see it is like a shorty header. So not too bad of restriction but will come up 25-30 short due to that. I do plan on running it both ways on dyno as I have future plans to add lightning headers and would like to see the diffeence in headers snd manifolds. Should be fun either way. Well over 100 mph either way. If I lose 3mph from exhaust so be it
mggdoors is offline
Old 01-19-2019, 09:58 PM
I did look at that exhaust as well but it is pricey. And my daytona has to have custom tails due to lower outlet than stock bravo. About 3” lower
mggdoors is offline
Old 01-19-2019, 11:04 PM
Originally Posted by mggdoors
Dyno will be posted in about 3 weeks. More than happy to share results. I posted this in the first place to be informative, not to start a pissing match.
I'm just trying to get you to your goal.here you go,,pay close attention to the cam,and this is more cubes than yours .
https://americanpowertrain.com/i-238...65-ft-lbs.html
sutphen 30 is offline
Old 01-19-2019, 11:24 PM
1-i-23887194-gm-427-ls-series-dressed-fuel-injected-drop-in-aluminum-heads-hp-torque-625-hp-565.html
Watch this. Look closely at the chart. Same exact specs on cam but using less lift and xfi lobes. It DOES have gm performance cnc heads which are good for 20 in the range hes in. My lobes will make more power than the xfi lobes.
mggdoors is offline
Old 01-19-2019, 11:51 PM
you gonna be dry sumped.and I'll bet the correction factor of that pull was 10%.but its your build,again,good luck.
Old 01-20-2019, 10:53 AM
525s make 560 in dyno trim with the different correction factor than merc uses. I’d be interested to see if your engines are any faster. The weight reduction will help.
Old 01-20-2019, 06:25 PM
I have a LS build also.
6.2 aluminum blocks
821 heads (ported)
Manley pro flow valves
Manley severe duty exhaust valves
Howard’s 98113 K1 spring kits
Howard’s ASA cams with 3 bolt
flat top pistons
full roller comp 1.8 rockers
mellings 10355 oil pumps
15 lb flywheels
light weight starters
Teague custom marine crossovers
dual 150 thermostats
aluminum sheet metal intakes
102 mm throttle bodies
thin head gaskets
Hot Rod 29 is offline
Old 01-20-2019, 08:42 PM
6.2 aluminum blocks
821 heads (ported)
flat top pistons
15 lb flywheels
thin head gaskets
keep us updated on this
mggdoors is offline
Old 01-20-2019, 10:07 PM
Received 1,322 Likes on 693 Posts
I heard about your 67 gto death grip ride. Bad azz from what I heard. What ratio rockers you running. I may have missed in OP.
Dennis r built and just sold a while back some stroked ls3 with ls3 cnc ported heads and made like 650 hp at 6,500. Ck out his build sheet. Ran them in a 32 sunsation 88 mph.
getrdunn is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell or Share My Personal Information -
Copyright © 2023 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
