LS Build: In Progress
#532
Do yourself a favor and pull the intercoolers and gusset them. Also run the zl1 lid if possible. Good for 20 or so hp and intercooler is more efficient. Port them as well. I did mine. Pay close attention to the area right above the gasket area that mates to head. Youll notice square edges. Round those out and open them up. Injectors I would decap the zl1 injectors and have them cleaned and flow matched. Good for 105lb/hr. And cheap. Last but not least a nice little trick if you dyno them and your ecu has capability is to fire injectors the second the intake valve opens or 0-5 degrees before and stop them at or before the valve closes. Easy BIG hp gain and does let fuel pool behind calve/cleaner afr etc. I actually showed my dyno guy this and he couldnt believe the gains. Over 40hp in my case. If you have overlap and can get enough fuel in within the valve event I suggest injecting after the overlap event. But only if you can get adequate fuel in by the time it closes.
Now a direct injected engine, especially a diesel, yeah, I can see by advancing injector timing there can be a power optimization
