Which oil cooler should I use for 450hp 468?
My engine build is finished and I’m wondering if the stock oil cooler from the 330hp 454 is sufficient to cool the new engines oil. The new engine is a 468 with 9.6:1 cr aftermarket iron heads and a crane 781 camshaft. Valvetrain is full roller. Exhaust is aluminum Gil with thru hull. I’ll be using a stock 385hp magnum oil pan (not sure of capacity yet) and the boat will do extended run times at 3500-4000 rpm. Some run times may exceed two hours. Sea water temps from 60-75 degrees. Any advice? Did I offer enough information? |
It will most likely be fine. The 330 oil coolers were used for the 420's as well as 454/502 mags.
Originally Posted by pjv911
(Post 4670066)
I went with this for 585hp
Hi-Performance Combination Power Steering & Engine Oil Cooler, 3" Diameter, 23" Overall Length, 3/4" NPT Oil Connections, 3/8" NPT Power Steering Connections, 1" NPT Water ConnectionHave you made some performance modifications and you're now making mega horsepower only to find out your stock Mercury cooler can't keep up? Well not only is this our most popular combination cooler, it is also the answer to getting those oil temperatures back down where they belong. This cooler features seventy-six 1/4" seamless cooling tubes and can handle form 450 to 750 horsepower applications with ease. With a 23" overall length, 3/4" NPT oil connections, 3/8" NPT P/S connections, and 1" water connections, this is the perfect solution. |
Some of the 330hp oil coolers where small post the size you have. I would use 2"x18" min. |
hp 500 cooler would be perfect and a good used one should be easy to find.
Originally Posted by mike tkach
(Post 4670513)
This should fit your needs, - H/P Oil Cooler :: Oil Coolers :: Engine Oil Coolers / Oil Systems :: Diamond Performance Parts
Thanks for the replies guys. I still need to install the motor. Actually the boat is still shrink wrapped with the old 330 in there. Lol. Hopefully I can get this swap started early March and I’ll see what I have. I happen to have a big diesel marine cooler too. No idea what hose sizes are but it’s about 18” long and 3” think. Maybe that’s a good option. That’s in the warehouse so I’ll take a look. I just now remembered I had that while responding. I’ll post the info on it here. I’m sure there is some reason it won’t work out but.... |
I'm sure your planning on it but just make sure you run an oil stat. |
| All times are GMT -5. The time now is 03:06 AM. |
