Stroking a Merc Racing 525 EFI to a 540 with Whipple Charger? Anyone do this ?
Has anyone done this with good success or is it even possible with injection? Wondering if it will over work the Whipple at that point?
Is there a problem with the 4" stroke that you currently have, or do you feel the need to upgrade?. If you are going to add positive pressure to the intake plennum there really isn't any need to add more cost adding cubic inches. Second, are you stuck on a Whipple or would you consider something new and more efficient with greater flexibility?
If it uses the 3.3 I do not see a problem with it, especially if you go with the stage 2 larger chiller. Your compression can be adjusted accordingly since you would most likely be going with all new pistons anyway. Then you can just say "fuk you bravo drive, I am going to turn you into scrap metal.
