-   -   Merc DTS Wiring diagram? (https://www.offshoreonly.com/forums/general-q/359187-merc-dts-wiring-diagram.html)
15x 02-21-2019 09:26 AM
Looking for assistance finding wiring pin outs/diagrams for my 2009 SeaRay Merc DTS Controls & smart craft module. Have had no luck online researching.
Thank's in advance, Scotty
BUP 02-21-2019 11:37 AM
You can buy them them thru a Merc dealer and I know I have them stored away. Maybe this weekend I could look for those manuals. I would be willing to sell them. But 100 percent have to ask and I am not pointing my finger here but If you are not interested in buying the manuals PLEASE let me know because I do not want to waste my time looking for them. Thank you
15x 02-21-2019 12:21 PM
Do you have the full wiring diagrams or are they just for the DTS? I don't mind paying if you have the time...
BUP 02-21-2019 12:28 PM
there is couple of options in the manuals. I do not have them in front of me as they are stored away. What is your engine and is it a single engine or TWIN Sea Ray ? -- of course Mercruiser and a 555 controller . If you have engine serial number give it to me - I can run it to see what exactly you have and set up.
Are you having issues ? or ? just asking
do you have a 496 or a small block ? this will determine which 555 you have. There is Smartcraft / DTS wiring diagrams and of course ECM / PCM wiring diagrams. Also diagrams for single engines / twin engines / trips engines and so on
Best if I knew your exact set up THANKS
15x 02-21-2019 01:15 PM
Mine is a 2009 Pachanga with the single 377Mag. Wanting to use my existing DTS controls with our new 6.2 LSA GM Crate engine that uses an automotive type ECM.
Engine Serial # 1A344800
15x 02-21-2019 04:26 PM
https://cimg7.ibsrv.net/gimg/www.off...3d03165270.jpg
Thought I'd show you what I have so far but its not very detailed as far as wire pin out locations or colour.
15x 02-26-2019 11:28 AM
Any luck?
BUP 02-26-2019 11:50 AM
not yet but I have not found them all. Actually I will know more tonite or tomorrow when I get a chance to pull more manuals out of storage.
Wildman_grafix 02-26-2019 01:44 PM
Which crate motor are you using? Is it CAN Buss, CAN NEMA 2000 Buss, or GM ethernet?
15x 02-26-2019 03:34 PM
Using the GM Performance LSA 6.2L, having a harness built & using a GM ECM. I think the factory Merc is Can buss, not 100% sure what the GM unit uses.
