Transom light mounting
I'm about to mount some underwater transom lights on my boat. As of now, I'm using a pair of Seablaze X lights. I really don't want to have three lights, so based on two, should I mount them between the drives or outside of the drives. If I absolutely should have three I can go that route, but if two will work, I would prefer to do that.
Here is a picture of the transom.
2 in the center between the drives works. Here you can sort of see where mine are. Personally I would go with 4 if $$$$ didn't matter. 2 in the center and then 1 on each side of the drive.
I do not have your brand but installed 3 on ours. 3 Would be my suggestion for a nice spread light pattern, if budget allows. If 2 were max, mount on the outside of drives.
If that’s what two lights are capable of, I’ll be fine with two! I guess if I need more, I can always add some to the outside of the drives. Thanks for the pictures.
I figured those pictures were not taken with an iPhone, lol. I keep my boat in Northern Lake Michigan and the water up there is like a glass of drinking water, crystal clear. If those pics were taken in one of the Chicago harbors, I'll be fine with two.
Transom lights are mounted. I was told to go as low as possible, so when on plane it will light up the wake better. I don't think I could have gone any lower. I'm pretty sure I'm going to add two more lights on the outside of the drives. I'm make up my mind on that, as soon as I get it in the water.
