-   -   Engine check up (https://www.offshoreonly.com/forums/general-q/359647-engine-check-up.html)
Franks292 03-18-2019 11:48 PM
Engine check up
So my 2002 Formula 292's 350 mags have 475 hours on them. I planned on doing a compression and leak down test, plugs, wires, etc. What else should i check? The boat is getting new exhaust and hydraulic steering so itll have some down time. Any input is appreciated!!!
TomZ 03-19-2019 11:35 AM
You could do those things for piece of mind, but doing compression and leakdown tests on those motors is probably not necessary unless you've noticed a problem. Oil change, plugs, wires, cap and rotor are probably all they'll need. The 350 Mag so long as the manifolds are good, will run for a really long time. 475 hours is nothing on the valvetrain. If the manifolds are good, I'd leave'em be.
cigrocket 03-19-2019 11:51 AM
I agree, unless you hear something, or performance is down. Oil change, plugs, wires, cap and rotor and routine maitenance is all that is probably needed. Manifolds are sometimes a problem, but if freshwater run then usually not an issue. Many people put 1000 hrs without opening. Reliable setup.
Franks292 03-19-2019 02:19 PM
There aren't any noises or anything out of the ordinary. I come from the hot rod world where every couple years I look over my engines and do a few test so it's just force of habit. The previous owner of my boat was extremely punctual and meticulous about maintenance, so I doubt I would find anything wrong but I'm a worry wart lol. I got 2 sets of IMCO powerflow manifolds with stainless tails from a boating buddy, which is the only reason the stockers are coming off.
TomZ 03-19-2019 02:22 PM
The stock parts have caused more wasted engines that anything! You'll like the new exhaust.
Franks292 03-19-2019 02:35 PM
Yes the weight reduction and slight performance gain with the powerflow is a win win. My 292 isnt quick to plane out so the less weight the better.
Zach F100 03-21-2019 08:48 AM
