889275T Fuel Pump Assembly
Is this just a lift pump for an electric fuel pump? Or is it regulated to run a carburetor off of? I show's it will run off a sea pump from 525EFI-799SCI. Need a sea pump fuel pump.
https://www.mercruiserparts.com/889275t-pump-assy-fuel
Thanks
Thanks
Would need to know what motor, but
You want 861677T
https://www.mercruiserparts.com/861677t-pump-assy-fuel
or Airtex 60932 which makes the pump for Merc
You want 861677T
You want 861677T
https://www.amazon.com/Airtex-60932-.../dp/B002HTYRD8
You want 861677T
is the airtex a direct replacement for the merc. Bolt and go?
You want 861677T
You want 861677T
The engines are NA 502's Will this pump support 600HP NA?
Ive got a pair of sea pumps if you need them
I'm running a Gen 2 cool fuel (530hp) without a mechanical pump in front and have no issue, and also the pump moves more fuel then my motor will use
